Hi There
I'm new to frame generator and still trying to get the hang of things.
I have done a 3D sketch which I have then mirrored and have used this as a template for my Frame.
However, I have now realised that this may have caused a small problem as I am now in situation where I have two beams that are colinear when all I need is one beam.
Looking at my image below, basically I want to know how to merge two beams together. I am aware when you intially select your lines when inserting a frame you are given the option to merge two beams together. But now how do I do it after I have already inserted the beams as when you go to change frame, the merge button is not there. At the same time when I delete the two beams I lose that line in my reference model which I don't think is a good thing.
Any help on this would be great! Thanks.
Regards
Nikhil Makan
