Inventor Forum
Menu Bar messing up
1 REPLY 1
Paul-Mason
432 Views, 1 Reply
Menu Bar messing up
In IV 2017 every now and again the menu bar,all of them, depending on what environment I'm gets messed up as below
A right click then Ribbon Appearance, reset usually corrects it BUT as I move some of the items around that rests them to the default position. I find it more of an annoying nuisance that anything but just the same it should not be happening and I don't know why it just suddenly happens.
Has or is anyone else having this problem, is Autodesk aware of it ???
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Tags (2)
1 REPLY 1
Marco.Takx
in reply to: Paul-Mason
I have seen this problem before.
The only way I know to reset it is to press 4 times on this button.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
