- Mute
- Permalink
- Report
As a designer you learn all kinds of programs and try to make best use of it. For my graphic work i use Corel. For a poster for a theatre play I had to use a picture from the internet that I couldn't find in sufficient resolution. No problem, there is Trace, generating a vector drawing from bitmap. When I did this from the bitmap below it turned out to be so coarse that a steplike zigzag line was created. No problem I thought, these are very geometric figures, lines and circular arcs, all i have to do is draw them on top of the vectors from Trace. Well, that didn't work too well...
The figures :
The bitmap is 100k maximum. On my old Dell laptop with 2GB memory and Windows XP SP2 (shows how old it is, millenium stuff) it took no more than 2 seconds to generate the vectors. Corel afterwards needed about the same time to translate this into a 1MB DXF-file.
The CAD-machine is an Intel Xeon 2.8GHz - 8 cores - 12 GB RAM. I first opened the DXF in Autocad to copy-paste it in an Inventor sketch afterwards. Now here it gets intresting. Autocad took minutes to import the DXF and show it on screen. Again minutes to transfer it to Inventor and then...
Nothing was moving anymore. I looked at the task manager and saw that the memory graph was hitting the ceiling. All 12GB in use and Windows trying to manage.
Not expecting answers here but i find it entirely "over the top" that a 1MB DXF can turn in a 10GB memory block.
Alex
