Measure Tool Problem
jingying_1213
jingying_1213
When I start the measure, it is set to "Part Priority" as shown below in yellow circle.
However, I will need change to "Select Faces and Edges" every time. Can I set it to "Select Faces and Edges" as default?
Thanks!
Alexander_Chernikov
This is strange, my program remembers the last used filter. Check that the latest updates are installed (2023.2) and try using the reset utility (via Start while the program is closed)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
jingying_1213
After restarting Inventor, the problem was fixed.
Thanks.
