Some years ago a kind person provided the attached iLogic code. As I recall, the name of the sweep feature or the sketch has to match the one referenced in the code.
'Set a reference to the active part document
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim opath As Path
opath = oDef.Features.SweepFeatures.Item("TheSweep").Path
Dim TotalLength As Double
TotalLength = 0
Dim oCurve As Object
Dim i As Integer
For i = 1 To opath.Count
oCurve = opath.Item(i).Curve
Dim oCurveEval As CurveEvaluator
oCurveEval = oCurve.Evaluator
Dim MinParam As Double
Dim MaxParam As Double
Dim length As Double
Call oCurveEval.GetParamExtents(MinParam, MaxParam)
Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, length)
TotalLength = TotalLength + length
Next i
Dim oparams As Parameters
Dim oparam As Parameter
oparams = oDoc.ComponentDefinition.Parameters
Dim exists As Boolean
exists = False
'Find out if parameter exists
For Each oparam In oparams
If oparam.Name = "Sweeplength" Then exists = True
Next oparam
'Change the value if the parameter exists otherwise add the parameter
If exists Then
oparams.Item("Sweeplength").Value = TotalLength
Else
oparams.UserParameters.AddByValue( "Sweeplength", TotalLength, 11266)
oDoc.Update
Here are some more ilogic methods:
https://forums.autodesk.com/t5/inventor-forum/sweep-length-measurement/m-p/9567405#M791937
Steve Walton
Inventor 2025
Vault Professional 2025
