MBD Dimensions have a line through them
todd.rathier
todd.rathier
I have used MBD dimensions with Inventor on my system before, but for some reason I am getting a line through the text of the dimensions today. Any ideas on fixing this?
kacper.suchomski
Close the program and run it again. Check what will happen.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
todd.rathier
Weird, and I probably should have thought of re-starting Inventor. Thank you!
todd.rathier
This is still occurring. If I save the part in "Wireframe with Visible Edges", close Inventor, then re-open the part, it comes up as "Shaded with Edges". So, apparently, the visual style does not save. If I now switch to "Wireframe with Visible Edges", the lines are back. This happens on every part. I have attached one to see if it is my system configuration.
Dell Precision 5820 Desktop
Windows 10 Pro for Workstations Version 21H2 Build 19044, 1645 64-bit
Intel Xeon W-2225 CPU @ 4.10G GHz, 4 cores
16GB 2x8GB DDR4 2666MHz RDIMM ECC Memory
2.5" 256GB SATA Class 20 Solid State Drive
NVIDIA Quadro P2200 5 GB GDDR5X -  Hardware Acceleration is On
Inventor Pro 64-bit Build 271, Release 2023.2
kacper.suchomski
You can test different recording variants. If the problem persists, you can report the topic on Idea Station as a bug in the program.
@johnsonshiue, do you know if this bug is known?
Kacper Suchomski
johnsonshiue
Hi Folks,
I cannot seem to reproduce the behavior on my machine. Try this and see if it helps. Go to Tools -> App Options -> Display -> select "Use document display settings." Does it work better now? Or, you want to use Inventor Reset Utility to reset all settings back to the install default.
Many thanks!
Software Test Engineer
