Oh, you are still on IV8? I think I still have a IV8 version, and they will
probably be OK. I had to dig them out of my archived IV8Library
files. I've included a 4-way, 2-way and oblong 4-way. All you should
have to do after inserting them is go into their Parameters dialog and
scroll all the way down to the User Params, change "Contact_Diameter"
and"Body_Diameter", then update. Note that there are some limits
involved in the difference between these 2 params, especially the larger
the difference is. You MAY have problems if you want to change the taper
amount, hard to say. They are currently 15 degree tapers per side
(30 included).
Bob S.
"John-IV8SP1" wrote in message news:42446d26_3@newsprd01...
> Any chance I could talk ya into sharing that template file?
> "Bob S." wrote in message
> news:424467c5_2@newsprd01...
>> I do something SORT OF similar for my RFS datum pins (Tapered spring
> loaded).
>> Only what I do is start with a circle at the nominal size of hole on one
> of the origin
>> workplanes, then extrude it with a taper amount in both directions.
> Getting the direction
>> of the main pin body to end up at a STANDARD size was a bit tricky though.
>> I now have a standard template part I use for these pins, and all I need
> do is
>> edit the parameters for the contact diameter and the pin diameter (which I
> usually
>> make the next largest standard diameter larger than the nominal hole
> size).
>> Now all I have to do is use 2 mates, one to the pin axis, the other to the
> origin
>> workplane and the hole face.
>> "Nick Hasselblad (Autodesk)" wrote in
> message news:42446461$1_2@newsprd01...
>> > Another method is:
>> > 1.use the Split tool to create a split line around the circumference of
> the tapered part
>> > -use a workplane (normal to the axis of the part) as the split tool
>> > 2.set an Insert constraint between the split line and the hole edge.
>> > "orchdes" wrote in message
> news:8882146.1111711141934.JavaMail.jive@jiveforum2.autodesk.com...
>> >> See Harry G. Post first.
>> >> If that doesn't work try this.
>> >> 1.) Place mate constrain between pin axis and hole axis.
>> >> 2.) Activate Contact Solver on these 2 parts.
>> >> 3.) Drag the tapered pin into the hole. It should stop at the tangent
> point of contact. Then constrain with predict on. Or if you
>> >> have a constraint located in the direction you would drag the pin you
> could drive this constraint and it will stop at the hole.
