materials missing
materials missing
MikeKovacik4928
Advisor Advisor
Message 1 of 18
materials missing
MikeKovacik4928
Hi all
My materials are missing, all I have is generic, nothing else.
What might have happened? How can I get the materials back.
If I open an old ipt the only the material used for that particular ipt is there,
the rest have disappeared
Mike Kovacik
Inventor/AutoCAD Draughtsman
Johannesburg, South Africa
Inventor Pro (Part of Product Design Suite Ultimate) 2018
Replies (17)
Message 2 of 18
blandb
Just making sure you are not choosing the material drop down from an assembly:
Versus the actual part:
Autodesk Certified Professional
Message 3 of 18
Cadmanto
@MikeKovacik4928
What's changed since the last time you used all of your materials?
Any updates? SP's loaded?  Are you using the same project file?
Do you have custom materials added to the Inventor material library?  If not, have you tried using the Inventor Rest Tool?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 18
MikeKovacik4928
No
I am definitely in the .ipt file
Mike
Message 5 of 18
MikeKovacik4928
Scott
No updates or sp's. No custom materials added.
I use different project files.
I have tried opening  ipt's  in a few of these different project files.
The material I set the ipt to is still there, all other materials gone.
New ipt files, generic material only
I have not tried using the inventor reset tool
Mike
Message 6 of 18
blandb
Can you change materials in the iProperties?
Message 7 of 18
MikeKovacik4928
No, they don't even appear in the scroll down list.
They have vanished
Mike
Message 8 of 18
johnsonshiue
Hi Mike,
Try this. Close Inventor. Go to %temp% and delete all files there. Reboot. Start Inventor. Does it work better now?
Many thanks!
Software Test Engineer
Message 9 of 18
MikeKovacik4928
Johnson
Not too sure which files in which directory you are talking about.
This was all happening last night on my laptop.
On my desktop now, with the same software loaded (Autodesk Product Design suite Ultimate 2018)
no problems at all, even with those same drawings from the laptop last night where the materials had disappeared.
So the problem is on my laptop only, something must have happened there.
Can I not reload the materials files from my original software stick. Where would they be located
Mike
Message 10 of 18
Cadmanto
Mike,
Still haven't tried the reset tool?  Sounds like a perfect candidate!!!
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 11 of 18
MikeKovacik4928
How weird is this.
I have copied the files back to my laptop from my desktop where the materials were showing.
The materials are now showing on my laptop.
I don't understand what happened or why it happened.
But it has now fixed itself, again no idea how or why.
Oh the joys of computers and software!!!
Mike
Message 12 of 18
johnsonshiue
Hi Mike,
I was talking about system temp folder. Close all apps. Go to File Explorer. Type in "%temp%" and delete all files in that folder. Then restart your machine and Inventor. Does it work better now?
Many thanks!
Message 13 of 18
simon4D86F
I had the same problem, running the "Reset Tool" worked a treat.
Message 14 of 18
timothy_berg
This is happening to me as well. It happens when I change from one project to another. I don't see how the Reset Tool will fix this when the project file is controlling where Inventor pulls materials and appearances? Fyi the material and appearance library I use are custom.
Message 15 of 18
johnsonshiue
Hi Timothy,
I think the Inventor Reset Utility may help redirect the default Appearance and Material Library to the default one. I don't believe it will help your case. I suspect there is a temporary memory corruption on the machine. Somehow Inventor could not find the proper library at the moment. There is bug somewhere for sure. Typically, if you restart Inventor, the issue will be gone.
Many thanks!
Message 16 of 18
timothy_berg
Yes restarting Inventor does fix the problem, thank you for your help.
Message 17 of 18
iklompe
Also having this problem, of materials not showing, and it is not solved by restarting, rebooting or cleaning up temp directory, because it also does not occur every time, it sometimes does, sometimes does not.
Say 50% of the times it looses the materials.
And that is really strange.
Message 18 of 18
johnsonshiue
Hi! I would like to double-check with you. When the material styles are missing, are you editing an assembly? If yes, it is as designed, because there is nothing (except weld beads) to assign a material style too.
Many thanks!
