- Mute
- Permalink
- Report
Hi
I very often use multi-body parts (sheet metal, standard and combined - sheet and solid in one part).
From some time, I have a problem with assigning materials to parts derived from these multi-body parts.
When I assign material to derivative part, and after editing multi body part, the material in the derivative part resets to default.
Also, when rebuilding assemblies, in some derived parts material is reset to default, and some do not.
Im observing the same problem in Inventor 2018 and 2019.
Does someone have an idea what is the source of that problem.
This is a quite a problem for me, because several times I have sent drawings with material set as default. Also, after every rebuild I have to assign materials to dozens of parts.
