Materials & Apperances
Hi
I dont think the Materials & Appearances will ever work properly.....
Summary
I have 1 ADSKLIB files that holds both material & appearances
i have my textures folder set in my Application Options and my materials & appearance look there for the images
Material first
I edit my material, select my image, browse to teh image in my textures folder and everything looks ok. I click apply then close the editor. I re-open the material and nothing has updated. the image is no longer there and the color has set back to the default...
Appearances
I have 4 MDF material types MDF, MDF Laminated, MDF Veneered & MDF Painted. All materials should share the same image and trhe only real difference is the name HOWEVER... The appearance library creates this
Whats more frustrating is, i cant even delete them........
Whats the deal? Why doesnt this work?
Is it possible to
Add or edit a material, and assign one of the appearances from the library instead of the materials & appearances being completely independent? surely it would make more sense to create your appearance in the appearance library then assign that appearance to a material?
i wont even get started on the 1" wide material & appearance dropdown widths that sometimes are justified left & sometimes justified right for no reason whatsoever......
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
