I have assembly made of 11 parts and a sub-assembly. I have employed user parameters on one of the part files (base component) to define the key dimensions of all the other parts (derived parts). When i make changes to the parameters on the base component, the parts update and render as they should. The individual derived parts files update their physical properties too, namely mass, area and volume.
The problem is, for one of the parts on the assembly, its mass, area and volume values are stuck. It always shows the same number and do not change even after rebuild. When I tried component replace, the mass, area and volume field appeared blank and when I clicked on Update, the same incorrect numbers appeared again.
Does anyone know what is going on here?
I am willing to supply more information if required.
Properties of the part in the BOM (mass is 742.045Kg)
Properties of the part in the assembly (mass is 3863.353Kg)
Properties of the same part in the part file (mass is 742.045kg)
Addition (5/5/2022):
This has led to the incorrect mass for the sub-assembly (AC-10-110) being registered in the assembly (AC-10) and its BOM.
In summary:
Part File : Mass correct
Sub-Assembly file : Mass Incorrect in model, Mass correct in BOM
Assembly file : Mass incorrect in Model, Mass incorrect in BOM.
