Announcements
Making Sketched Circle a Construction in Inventor Drawing
drlou
drlou
Inventor is not letting me create a centerline radius between two holes centered around the origin of a drawing. I would like to sketch a circle, centered on the origin, that goes through the middle of each hole that are equidistant from the center (origin) of the part. To do this and clearly differentiate this circle from any real feature of the part I need to be able to turn the sketched circle into construction, or at least be able to manually edit the line composition. I am having a hard time finding this option while making the drawing, while it is really easy in the normal part view. When selecting "centerline" while in sketch mode, this has no impact on the composition of the circle I am trying to place over the axis of the holes. If creating a centerline through these two holes, that creates a circle and allows me to define that diameter that would be even better, but after trying for 30 minutes it doesn't seem possible. Thanks for the help!
Replies (12)
JDMather
@drlou wrote:
...If creating a centerline through these two holes, that creates a circle and allows me to define that diameter that would be even better, but after trying for 30 minutes it doesn't seem possible.
Can you Attach your *.ipt file here.
That should be possible in the drawing.
johnsonshiue
Hi! Yes, I think JD is right. This should be doable without having to create a sketch. Here is the workflow.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
You may be able to find videos showing the same (keywords: Autodesk Inventor centerline pattern).
Many thanks!
Software Test Engineer
drlou
Can I send it to you directly? The project is export controlled and I don't want to toe that line. It's the reason I took a screen shot instead of posting the entire drawing.
drlou
If I have 3 holes, ie not two holes that are 180 degrees apart from each other, this works just fine, but when attempting that style of workflow, Inventor wants to create a center line through each hole and not define a circle that encompasses both holes, with the origin at the center.
andrewdroth
You need to use the 'centered pattern' centerline option as shown in that link. You will select a circle that the pattern is centered on first, then the two holes in question. If you use the regular centerline option it will just draw a straight line.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
drlou
I slowed this down to half speed and took note of every click you made, and in my case Inventor reacts the same until I select the 2nd hold (3rd right mouse button click after selecting centered pattern in the video), and instead of giving me another centerline cross, it doesn't show anything (as it normally does for me when doing "centered pattern"). It is highlighted in blue (so I know Inventor selected the correct hole), and then the 4th click that should ask inventor for the centerline circle doesn't happen in this case. I have verified these holes are at exactly the same distance from the center axis of the part and they are the same diameter, so I am still confused as to why this won't work. I have used the "Centered Pattern" drawing annotation many many times (twice already on this specific part drawing) and this is the first time, I can't for the life of me get it to work properly.
JDMather
@drlou wrote:
The project is export controlled ...
Can you create a simple dummy dataset?
That is what I would have to do on my end to create a video.
I was simply hoping that you would save me a few minutes but doing those initial steps.
drlou
Yeah I understand, I will post a dummy file soon, hopefully by the end of today or tomorrow morning. Thanks for everyone's help btw, I really appreciate the community here.
andrewdroth
Weird, IV must think they are not centered for some reason. Is there any chance the center pick circle is off the origin a bit?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
Does it behave like the first try here where the center circle isn't centered? Can you pick a different starting circle?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
johnsonshiue
Hi! Andrew and JD are right. It should work. Or, like Andrew said, the holes are not in a precise circular pattern. Please share the files here or send them to me directly (johnson.shiue@autodesk.com). There should be a logical reason to explain the behavior.
Many thanks!
IgorMir
Yes, it does. There is absolutely nothing special about this particular annotation. But without seeing the actual file from the OP we can only guess as to what's going on at his end. Here are two files in IV2020 format. In order for the pattern to work - the center hole (it it exists) should be picked up first. In my example I have just picked the contour of the part itself for first selection.
Cheers,
Igor.
Many thanks!
Web: www.meqc.com.au
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
