making part to fit another part
Message 1 of 12
Hi
What technique would you use to make an O-Ring part so it fits into Sweep-2 shape from the attached part "seal". I will then constrain in assembly mode the 2 parts?
James
Accepted solutions (3)
Replies (11)
Message 2 of 12
JDMather
Make the 3D sketch visible.
Start a new part file.
Manage tab>Derive Component and derive the 3D sketch into the new part file.
Sweep the o-ring profile.
Make sure your Profile plane is perpendicular to the sweep path curve.
Message 3 of 12
CCarreiras
Hi!
You can do this several ways: multisolid, derive part, in assembly context (by copying the face)...
I Created the O-Ring based in the derive part method. That way both parts will maintain associative, therefore, if you change the part, the O-Ring will re-adapt accordingly.
Check it!!
CCarreiras
Message 4 of 12
CCarreiras
BTW, later, to constrain both parts in the assembly, you can make coincident the seal planes with the O-ring planes.
CCarreiras
Message 5 of 12
JDMather
Carlos - your O-ring is not created with the profile perpendicular to the path?
Message 6 of 12
CCarreiras
Hi JD.
The O-Ring profile (sweep)  is the same of the sweep in the part, so both have to connect perfectly.
CCarreiras
Message 7 of 12
JDMather
I just realized - the sweep in the original Seal part is not created correctly either.
The profile for the sweep should be perpendicular to the path.
Message 8 of 12
CCarreiras
I agree with you ...
but the question was not that, so ... i kept things like the "customer" Demanded. 🙂
CCarreiras
Message 9 of 12
JD, can you show me where i went wrong. Can you post my part showing correct technique so i can check
thanks
James
Message 10 of 12
JDMather
The difference is very subtle on this part.
The way you did the cut the profile of the groove would be slightly eliptical.
Recently someone posted an example of a longer sweep that was a couple of meg - reduced significantly with circular profile perpendicular to path.
Message 11 of 12
JDMather
On this example it is more obvious if I change the 8mm to 35mm.
Message 12 of 12
Thanks for pointing this out
