making a hinge swing a door in an assembly
seventhmoreno
Message 1 of 15
seventhmoreno
i am trying to make this hinge swing the door up and down i have created its own sub assembly where it is able to move but i cant figure out how to make it work in this assembly can someone please explain how to go about adding constraints ect.
Replies (14)
Message 2 of 15
mdavis22569
post the ipt's as well
Mike Davis
Message 3 of 15
seventhmoreno
which ipt's? for the hinge or the cabinet model?
Message 4 of 15
mdavis22569
..to open it properly you need to also post the IAM's that are in it
Mike Davis
Message 5 of 15
Curtis_Waguespack
Hi seventhmoreno,
See this link, and then be sure your subassembly is set to be Flexible also:
https://forums.autodesk.com/t5/inventor-general-discussion/flexible-hinges/m-p/3755822#M459034
I hope this helps.
Curtis
Message 6 of 15
seventhmoreno
Message 7 of 15
mdavis22569
As Curtis said you'll need it to be an Flexible assembly in whatever assembly you place it ...
TO do that go to the browser of the assembly it's placed in RMB and click on Flexible
capture 3.pngcapture 3.png(ps I know I have an unresolved, pictured first assembly I saw)
For your upload:
problem is I'm not sure where you're putting this or how.
I've tried to open your assembly..however
These 3 IPt's are missing
Mike Davis
Message 8 of 15
Mark.Lancaster
When you post an assembly you need all the files (parts and sub-assemblies) that make up the assembly.   Posting only the assembly is useless.
Mark Lancaster
Message 9 of 15
seventhmoreno
Message 10 of 15
seventhmoreno
Message 11 of 15
seventhmoreno
Message 12 of 15
mdavis22569
HERE IS A ZIP OF IT. OPEN ASSEMBLY 1 YOU CAN SEE IT WORK
I BELIEVE THIS IS WHAT YOU ARE LOOKING FOR
Mike Davis
Message 13 of 15
seventhmoreno
ZIP FOLDER IS EMPTY
Message 14 of 15
mdavis22569
sorry about that
Mike Davis
Message 15 of 15
Door is constrained to the cabinet. Constrain door to hinge only.
Nice cabinet BTWSmiley Wink
