Making a dynamic pallet racking
So im new to the 3d part and Inventor and are trying to do some self learning, but for now im stuck and cant seem to get any further.
So what i am trying to do is to make us a dynamic 3d pallet rack that we can use to make new models to use in factory design.
This on should be dynamic so we can change the following properties of it:
- The profile of the column (The profile include holes where both the beam and horizontal bracers should fit into)
- The height of the column (This is made whit a multi choice)
- The depth between the columns (We have 3 standard depths)
- The placement of the horizontal bracers (This are depending on the height of the columns)
- The profile of the beams (This is depending on what weight load we want)
- The length of the beams (Multi choice from standard lengths)
- The placement of the beams (Light opening between the beams)
The making off the column, horizontal bracers and beams are no problem.
The problem starts when im going to make the assembly. Im not getting the horizontal bracers to adapt to the height of the colum
How can i solve the wish to make placement/length of the horizontal bracers adaptiv to what length of the column is?
- If the height of the colum is 3000 mm, there will be 5 bracers, first starting at 163 mm (flat), distance to next is 550 mm, distance to next is 850 mm, distance to next 850 mm and one at top (flat) should be 181 mm form the top and down.
- If the height of the colum is 3300 mm, there will be 6 bracers, first starting at 163 mm (flat), distance to next is 550 mm, distance to next is 550 mm, distance to next 700 mm, distance to next is 850 mm and one at top (flat) should be 181 mm from the top and down.
How can i solve the wish to make the number of the beams and placement of the beams?
Are there any good guides out there thats is linked up to pallet racks and similar items?
Her you can see racking made that is not adaptive:
Here you can see the setup for the horizontal bracers:
The column:
