Hi all,
I essentially would like to know if its is possible to 'stamp' a very variable surface (different extrusion spacing, heights, widths, ...) into the face of a block. I thought it would be possible to extrude the block to next face/body, but it seems to not be that easy.
I am looking to make a box (3D printer) to fit in a PCB. As you can see from the image the PCB has lots of pins and I would like to make a somewhat tight fit around these pins. I believe this entails making a floorboard (in Inventor) that has holes in these exact positions. Is this possible?
Since the pins are soldered on myself, they can be a bit tilted and on a different height as I have in the CAD file. Can I also have this floorboard with holes that go all the way through and that are slightly bigger than the pins themselves?
Thank you alot!!
Best,
Robin
