Make holes independent throug several parts
GeorgK
Advisor Advisor
GeorgK
Hello together,
I have several plates which I would connect with the bolted connection generator. There is already a thread about a similar problem:
https://forums.autodesk.com/t5/inventor-forum/make-hole-through-several-plates/td-p/2973292
How could I make the holes independent editable and delete the bolted connection?
Thank you Georg
Curtis_Waguespack
Hi GeorgK,
You should be able to right click on the hole feature in the part browser and choose Explode.
I hope this helps.
Curtis
