Make component faces always parallel?
In Inventor 2016, (in an assembly) how do I make the faces of two or more parts always parallel with one another but without restricting their faces with being always being flush.
To illustrate (see attached pic) say if I wanted the "A" faces of both parts to always face the same direction (parallel with one another) but be able to move the blue box back away from the green box's face (as illustrated)--what is the assembly constraints method for this?  Solid Works has a simple "parallel" feature but it's not so clear in Inventor...
Currently, I'm having to use a flush solution but then deleting it so that I can move the component's faces away from flush... which I have to be very careful not to sping the component accidentally.
Please help!  This is driving me nuts!
admaiora
You can give a desired offset in the constraint tool window.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
PaulMunford
How about a 0 Degree angle constraint?
Paul Munford
Technical Onboarding Architect
Linkedin
I would like a way to perform this without pre-setting a distance offset right off.  Any way to do this?
JDMather
Attach your assembly here and end all doubt.
mcgyvr
As Paul stated above.. Use angle constraint.. set to 0 degrees.. Same as being parallel..
