Make component & Make part, Difference?
drawingsCHR7R
drawingsCHR7R
Hi all,
I am making a parametric model using the multi-solid workflow, I selected my solids and wanted to create the individual parts.
At which point I came across 2 options:
- Make components
- Make part
What is the difference between these two? Why would you use one over the other?
JDMather
There is no real difference except that Make Components places your part(s) into an assembly (if desired).
Both techniques create part file(s) from the bodies.
drawingsCHR7R
Understood, thanks JD.
ItsBehindYou
I have just searched this same question and found the answer useful too. Cheers
hansDPQMN
make components is usefull if you want to make a nesting
