Macro to create parameter and iLogic Rule
I need some help to make the below macro to run in some ipt already created.
  • Create parameter "Part_Area" with m^2 as Unit/Type and 1,0 m^2 as Equation > Export Parameter > Add (iLogic) Rule: Part_Area = iProperties.Area > Save & Run > Save IPT
Any suggestion where I could learn it will be appreciated too.
danmachen
Can you be more specific about the part property you want to capture?
I am assuming you want to measure the area, but the area of what?
There is some script you can learn on setting user parameters through ilogic here:
https://forums.autodesk.com/t5/inventor-customization/ilogic-code-to-create-a-user-parameter/td-p/31...
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
oh sorry! I need to assign the total area already written at model's iProperty to a new Parameter called Area_Part.
  1. Create the Area_Part parameter, with Unit/Type = m^2 and with the Export box selectedParameter.png
  2. Create a rule to assign the iProperties.Area to the parameter created (Part_Area)
  4. Save the part
In this way I may use the parameter in my Parts List to show the painting area.
danmachen
Try running the following code within the part rule and see if it works first.
Then you can try executing on save.
If you wish to display the trailing zeros, then change the parameter within the code as you wish.
Dim oDoc As PartDocument = ThisDoc.Document
Try
prop = oDoc.ComponentDefinition.Parameters.UserParameters.item ("Area_Part")
Catch
newprop = oDoc.ComponentDefinition.Parameters.UserParameters.AddByExpression("Area_Part", "100", "m^2")
End Try
param = Parameter.Param("Area_Part")
param.ExposedAsProperty = True
param.CustomPropertyFormat.ShowTrailingZeros = False
param.CustomPropertyFormat.ShowLeadingZeros = False
param.CustomPropertyFormat.ShowUnitsString = False
Dan Machen
