<_____LODFactoryRep>
mgreenland5KXBS
mgreenland5KXBS
When I try to open this part it generates this error message which takes about 40 cancels to disappear.
I deleted the all model states (except the primary, obviously) from an assembly which contained a sub assembly which contained this part. I now get this error message when trying to open the part or the sub assembly but, strangely, not when I open the main assembly. When in the main assembly, when I 'open' the part I find that there are what looks like two constraints masquerading as model states. The labels refer to things I recognise but more as dimensions or perhaps work planes than constraints.
The part is quite tricky to make and I'd rather not have to remake it. Any help in fixing it appreciated.
johnsonshiue
Hi! The behavior does not sound right. The file was saved in 2024.2. I cannot seem to reproduce the same behavior on 2024.3. Please install 2024.3 and report back the findings.
Many thanks!
Software Test Engineer
mgreenland5KXBS
Will do, likely tomorrow.
mgreenland5KXBS
Well, 2024.3 seems to have sorted it! Many thanks.
