Looking to add file subtype column on BoM
johnsGNP
johnsGNP
Hi all,
I'm currently working with an assembly that has both regular parts and sheet metals parts. I'm looking to filter the BoM by the file subtype (sheet metal vs regular part) as I know that Inventor already tracks that in the iproperties of the parts. Can you add that to the Column customization options? Or is there some other way of doing it?
I know the alternative is to add a custom iProperty and then add a filter in the BoM but it just seems foolish that I should have to do that to each part in this assembly (which is rather complex) when it's already tracked in some form.
Any advice/information would be greatly appreciated! Thanks.
gcoombridge
@johnsGNP I had a play with this and it seems you cannot access it in the BOM list. I found a way to access it with iLogic though. Run this rule in an assembly and it will iterate through all the leaf occurrences and create a custom iprop called subtype then populate it the File Subtype property from design tracking properties. The values will either be modelling or sheet metal. Then you will be able to filter by the new property in the BOM.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oPartDoc As Document
Dim oOcc As ComponentOccurrence
For Each oOcc In oDef.Occurrences.AllLeafOccurrences
	oPartDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
		Dim oPropSet As PropertySet = oPartDoc.PropertySets.Item("Design Tracking Properties")
		Dim oProp As Inventor.Property = oPropSet.Item("Document SubType Name")
			Try
				iProperties.Value(oOcc.Name,"Custom", "SubType") = oProp.Value
			Catch ' Do nothing
			End Try
Next oOcc
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
johnsGNP
@gcoombridge  that seems to do the trick. Thank you for your help!
miechh
Thanks for the code. Had to tweak the code a bit, because it wil also try to add the custom property to weld beads in a weldment assembly, which will raise an error. Also suppressed parts in an assembly will raise an error when trying to add the custom property.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
