Inventor Forum
Logging into Content Center?
4 REPLIES 4
321 Views, 4 Replies
Hi all,
I just finished downloading the educational version of Inventor 09. I am having trouble with the content center. When I open an assembly (iam) file and press the Place form Content Center button in the Assembly Panel. The Content and Vault log in window opens it has places to input User Name, Password, Sever, and Database. All of which are automatically filled in except the Password.
So, how do I go about logging into the Content Center? Is there a default User Name and Password to use or is there something I have to setup before using it.
Thanks for any help!
4 REPLIES 4
pauldoubet
Leave everything as it appears and the default password is blank. Click the automatic login box and then OK.
Ok, problem number two…
I did just as you said and I am getting an error message. It says “Autodesk Inventor 2009 could not find Data management services on localhost”.
I am wondering if something did not install right.
Thanks!
pauldoubet
Did you have any problems when you did the install? If so, I would recommend you uninstall and try the install again. I really don't know what else to look at unless you provide more info. You did not change any of the automatically filled in entries on the login screens did you?
Paul
henry.han
Hi, to use CC, you also need to install a server. The message is telling you that you don't have a server installed in the current machine (localhost). Try to install ADMS server to your machine and then try the default settings again. Hope that helps.
