Lofting
Lofting
BLD0550
Lofting
BLD0550
Hey all
I was wondering if there was a way to loft between  the 2 bronzish colored areas.
I know I can loft between 2 sketches that a solid, but this has a thin wall.
dave_taylor
Make (2) sketches on each inner face, projecting the outer profile of one bronze piece to one sketch, then do the same for the other.
Then make a loft from one sketch profile to the other. It will make a full solid.
Then use the Shell command and select the sides to remove the faces and set the thickness.
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
1. make a loft
2 combine
JDMather
@BLD0550
Lofting from solid faces gives much more functionality than lofting from sketches.
See Attached.
See the Conditions tab.
johnsonshiue
Hi! For face loop selection in Loft, Inventor only supports single loop profile. Multiple-loop profile is not allowed. You will probably need to create two Lofts. One is from the outer edges as Join and the other one is the inner edges as Cut.
Many thanks!
Software Test Engineer
