Lofted Flange Issue
Lofted Flange Issue
jkargasAC
Lofted Flange Issue
jkargasAC
All,
I'm having an issue with the way the lofted flange is creating a couple cross bends and wondering if you can help.  I've uploaded the part so you can see the issue and attached a picture as well, but the problem I'm having is when I create a lofted flange, its putting a cross bend in two different directions.  Is there a way I can get this to have the same cross bend that is on the front of the part to the back side of the part or is this just a glitch in how Inventor calculates it's bends?
Any help is much appreciated!  Thanks!
Jeremy
Thomas_Savage
Hello @jkargasAC
I think this is just the way Inventor creates the Lofted Flange.
I have attached an .ipt with the bends the way you wanted it.
I split the model. Mirrored it. Then Flat Pattern it.
Hope this helps.
Thomas.
Thomas Savage
Design Engineer
jkargasAC
That's what I was thinking would need to be done but was hoping there was another way.  Thanks for the model!
Jeremy
Thomas_Savage
You're welcome.
Thomas.
Thomas Savage
Design Engineer
johnsonshiue
Hi! Another option is to create the U shape Lofted Flange without having the two smaller flanges on the top. Then create them separately as flanges.
Many thanks!
Software Test Engineer
