Loft - Corner cut
Loft - Corner cut
Henrik_Lo
Loft - Corner cut
Henrik_Lo
Hi
Is it possible to loft those 3 lines and cut a corner, I can’t get it to work
Regards
Henrik
Alexander_Chernikov
If acceptable, Sketch10 should be modified so that the resulting surface completely intersects the body.
Then a surface is built and used to trim (Split) the part.
Attached is the result file (the surface may be hide).
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Henrik_Lo
Hi Alexander
Thangs for replying, nice,
Thangs for your time.
Regards
Henrik
