Lobsterback pipe in sheetmetal
FProcp
FProcp
I want to create a Lobsterback pipe elbow from sheetmetal.
The finished pipe elbow will look like this:
The flat pattern needs to look like this:
Is there any way I can bend each of the wings in to create a lobsterback elbow?
The finished elbow I have shown in the image is made up of four separate segments of 22.5° each.
But, I want to model it as one piece that can be bent 22.5° three times and then rolled in to radius of 95mm to give the elbow. There is some complex bending to be carried out 🤔..
I don't want it as four separate segments.
The final elbow is to be 90° bend with an ID of 190mm, wall thickness of 6mm and a bend radius of 380mm.
Franco
GMT +08:00
Replies (11)
JDMather
These double curvature bends will not work in Inventor sheet metal.
Might be able to get result with Unwrap (not a sheet metal tool), but I didn't give it a try.
FProcp
Can't see how unwrap feature would solve it?
I just think that Inventar cannot do it 😕
Franco
GMT +08:00
SBix26
Inventor sheet metal cannot do it.  Here is a 2020 file with a surface generated by the Unwrap tool (new in 2020).  It may give a good enough result to be useful, I don't know.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
Frederick_Law
Usually I make one segment.
Take the single flat and combine it to make the multi-segment flat.
You'll need to make the connection pretty small.
A long connection will not bend after rolling into a circle.
Also we leave a rectangle skeleton around the flat.
So its easier to roll.
In the end you don't really save much compare to making one segment at a time.
jyager
Curious what the point is of doing an elbow like this? You still have to cut it out, you still have to weld it...but this way you're adding an extra bending step and wasting a good amount of material as compared to doing a nested fish pattern gored elbow.
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
Frederick_Law
On light gauge sheet metal, you could bend by hand after rolling.
With all segments connected, final bend will have everything line up properly.
On heavy plate, we bump all the segments together.
It depends how much material, frame cut, forming, welding cost in your shop.
FProcp
"...Curious what the point is of doing an elbow like this?"
I think our shop prefers to make them like this because the welding is much easier and faster.
I normally just manually put the segments together but this time someone wants an accurate drawing of how we actually make them.
Franco
GMT +08:00
Yijiang.Cai
@FProcp , I use Inventor 2020 to create this sheet metal parts easily, and all of parts can be unfolded using flat pattern. Please take a look at the attachment. If it works fine for you, please accept it as solution.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
FProcp
Thank you but this is not really giving me what I need.
I would like and assembly containing all four segments where the segments can be unfolded within the main assembly.
I think in your model I have to open each individual part file and unfold it by itself.
They cannot be unfolded within the assembly and then a drawing created of that.
I think this is not a solution?
Franco
GMT +08:00
alewer
With some trickery (sweeps, fillet, thicken) you can absolutely get sheet metal flat pattern (not unwrap). See the attached file for an example. Depending on your needs, this might have some advantages over using unwrap.
FProcp
Wow, this is amazing!
Thanks.
Franco
GMT +08:00
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
