Loads and Constraints become unselectable in Stress Analysis
r_mignault
r_mignault
Hi everyone,
In Inventor Stress Analysis, I sometimes lose the ability to select anything under the Loads or Constraints sections in the Model Browser. Right-clicking gives only the generic context menu, while other sections like Bodies, Materials, Contacts, Mesh, and Results still work normally.
Double-Clicking in the model tree or clicking in the graphics window doesn’t fix it — it seems the browser and model get out of sync. Restarting Inventor restores functionality, and sometimes it comes back on its own, but I haven’t found a cause or pattern.
Has anyone else seen this or found a way to refresh the Stress Analysis environment without restarting Inventor?
System Information: Inventor 2025.3.2, Windows 11
Thanks!
johnsonshiue
Hi! If you have Data Exchange Add-In loaded, please unload it when you need to edit Inventor files. There are known issues that are caused by the Add-In. Another possibility is the browser panel getting out-of-sync. The right-click context menu shown in the picture should be in Model tab, not Analysis tab.
Many thanks!
Software Test Engineer
r_mignault
Thank you for your insights.
Data Exchange is not required and is not installed; at least, I can't find it in the Add-ins Manager.
I'm unsure where to find information about restoring the browser when out of sync. I did some googling without finding much help.
If I get this issue again, I'll report back.
johnsonshiue
Hi! Please share the ipt file that exhibits the behavior here. It looks like a browser panel corruption to me.
Many thanks!
