Inventor Forum
Linking Drawing Dimensions to a Table
8 REPLIES 8
Message 1 of 9
SteveFrey
1018 Views, 8 Replies
Is it possible to link the dimensions in my .idw to the table in the upper left corner?  I want the information in the table to reflect what is in the drawing.
I'm using Inventor 2012
Thanks!
Steve
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
8 REPLIES 8
Message 2 of 9
IgorMir
in reply to: SteveFrey
Hi Steve
I think you would have to convert your model into iPart. Then the dimensions will be available to populate the table.
Igor.
Web: www.meqc.com.au
Message 3 of 9
SteveFrey
in reply to: IgorMir
I'm not sure I understand.  Why would converting it to an i-part be any different?  Don't the dimension properties still reside in the file?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 4 of 9
sam_m
Sadly don't know a way to insert model parameters into a table but you can do it with a text annotation:
"Unit Height:  Model Parameter d0
Unit Width: Model Parameter d1" etc
Using the bottom row of drop-downs in the text editor dialog box...
Arguably not as neat as a table, but could draw a text box around it all...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 5 of 9
SteveFrey
in reply to: sam_m
Sam:
Could you send me a screen shot of where to enter this?  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 6 of 9
Hi SteveFrey,
It looks to me as if this is an assembly. Are the dimensions you want in the table available as assembly parameters?
If so you could check the Export box in the parameters dialog box and then they will be available as Custom iProperties. Then you could use a Parts list as the table and pull that information in. I'd consider making all of the information in that table custom iProperties also, just so that becomes container for all of the info.
Now if those dimensions you want to pull into the assembly do not exist in the assembly, you might need to go to the Parameters dialog box and use the Link button, and then Link to the part files and import the parameters.
I hope this helps.
Curtis
Message 7 of 9
Okay.  I will fool around with it and see how it goes.  Thanks again.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 8 of 9
SteveFrey
Oy! I got partway through but I'm having trouble. I've exported the assemby parameters but now I'm having trouble linking them. Some "training wheels" please. Thanks.
Steve
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 9 of 9
How to dimension table link to dimensions in drawing in autodesk inventor drawing
