Linking assembly files with an excel document drawing data from planes
01:02 AM
Good Morning All,
Is there any way to link an assembly file together with an excel document?
In a little more detail; we have a cylindrical extrusion with planes set at different degrees from the center, (45 degrees, 22.5 degrees, 90 degrees - see attached images). We then constrain different items to the cylinder at different heights.
What i am wanting to do is be able to make a constraint against three planes - one to constraint to the face of the cylinder, one to lock it into place at the desired degree, and the last as a dimension from the floor so it can be assigned a height, and then actually transmit that data across onto an excel document.
Is this possible?
