Lines not shown in views
hi guys,
I am new to Inventor, got a quick question,
why are some lines not showing up when I create a view? see images below.
image on the right is the solid object, when I create a view for it, lines are missing on the left side.
any help is greatly appreciated.
thanks,
blair
If possible, can you upload the files as it's pretty tough to tell what you've done from a single picture.
If the model is a IAM file, use the Pack and Go utility to collect all the required files. If it's a single part, then the IPT file and the IDW file will do.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
SBix26
It appears that this is an assembly, and that the outer container and some of the inner parts are set as Reference (showing as phantom-type lines).  These components are not taken into consideration when calculating view margins, so they're simply outside the view.  Either change the outer container to Default (right click on component in assembly > BOM Structure setting > Default), or edit the view and increase the Margin value.
Sam B
Inventor Professional 2017.3
Vault Basic 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
SBix
thank you, that was helpful, now they are showing up.
thanks again
SBix26
Great!  If you click on the Accept as Solution button in my answer, others will be able to find it more easily.
Sam B
