Lines are missing after Mirror command
On the first picture attached I have chosen the features for the mirror command together with the Mirror plane. On the second picture attached after the command only one feature are missing. I have used the same approach for each pattern and tried to add and remove features in mirror command. Is it a possible graphical bug?
Xun.Zhang
Better to have data please, it seems the surface merge together after mirror.
Thanks!
Xun
Yes that is correct. After Mirror command I have stiched the mirror with the original revolve.
What data do you need from me?
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If you can attach your part or use Pack & Go as .zip to include all files that would help to inspect everything.
Without the parts users cannot investigate to determine whether it is a modeling issue or program limitation. If the parts are proprietary you can send it to us directly or amend the part to dummy dimensions.
Please select the Accept as Solution button if a post solves your issue or answers your question.
