Line->arc
Line->arc
Message 1 of 10
Line->arc
Hi!
This is a very funny question
How do I create arc using line command?
Thank you!
Replies (9)
Message 2 of 10
JDMather
While in the Line command
move your cursor back over the endpoint of the line and sketch out arc.
Message 3 of 10
mcgyvr
Just adding a bit to JDs instructions...hold down the left mouse button as you are over the end point of the line then drag the mouse and it will sketch an arc vs a line..
Message 4 of 10
jtylerbc
Start the Line command, click to place both ends of the line as normal.  Then (without exiting the Line command) click and drag on the second endpoint to create an arc that is tangent to the line.
Message 5 of 10
JDMather
Message 6 of 10
Thank you!!!!!!!!
Message 7 of 10
@JDMather
@jtylerbc
@mcgyvr
Thank you for all your replies!
Now I understand how draw an arc using a line command as a continuation  of a line.
I don't understand how to draw an arc using a line command starting at empty place,
without an end point of the line
Thank you!
Message 8 of 10
mcgyvr
Thank you!
You don't.. Thats when you use the arc button vs line
Message 9 of 10
@mcgyvr
do you mean that I can't use the "line->arc"  in this case,
and  I should use an arc command?
Right?
Message 10 of 10
mcgyvr
@Anonymous wrote:
@mcgyvr
Right?
Yes.. Creating an arc while in the line command is only possible when there is a line first..
So if you have NO lines then you need to use the arc command itself..
