Announcements
Line Constrained
Line Constrained
I randomly draw this sketch why only this line is constrained?
undefined
Replies (15)
It's most likely constrainted to the mid point of the Horiz. line at the bottom.
I wish to know why it is appearing spontaneously? Usually I have seen after dimensioning only constrain can appear.
It's easy to do. You start a sketch and you pick the bottom line to start your profile and if you are close to the mid point of the horzi line Inventor thinks you want that line to start on the mid point and will put a Coincident Constrait to the mid point. If you don't want that you need to keep an eye on your pick and make sure you have a yellow dot at your pick and not a green dot.
swalton
F8 will show you all the current constraints in a sketch.  F9 will hide them.  Place your mouse pointer at the squares at the end of line segements or points to see constraints at those points.
F8 will not show any constraints you add to a sketch after you press it. You must hit F9 to clear the screen and then hit F8 to see the new ones.
There are also RMB menu picks to show/hide sketch constraints.
See http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EC368AD8-21A6-4207-85B7-E757DDB74272
Steve Walton
Inventor 2025
Vault Professional 2025
In order to alter the dimension I selected that dimension and click the Driven Dimension button but following error message is appearing. Please tell me how to alter the dimension.
undefined
mcgyvr
You need to remove whatever constraint is being applied to that line..
or enable "relax mode" https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Inventor-Help/files/GUID-A70EA377-475A-4A54-86B4-D653ED1708D0-htm.html
Post the ipt file if you need additional help (the one you posted originally does not have that sketch in it)
JDMather
The file you attached here does not match the image you attached here.
You must, of course, attach the file that exhibits the behavior you are seeing to get the best response.
JDMather
I recommend that you go through these
http://forums.autodesk.com/t5/inventor-general-discussion/skillsusa-document-now-on-screencast/m-p/5...
I am going to guess that you have AutoProject Geometry turned on (the default) which I never use because it projects stuff that you don't really intend to project.
I am going to guess that Inventor has autoprojected the bottom edge and your line is at the midpoint as stated here by others.
(but without the actual file - all is a guess)
undefined
If you are going to post only pretty pictures (rather than actual file) you should turn on the Constraint Visibility so that others can see the constraints that you should be examining.
Here is the file.
JDMather
Midpoint is midpoint is midpoint.  It is what it is.
It is an excellent explanation. Thank you very much for your help.
If I want to dimension from the edge shown what should be done?
undefined
JDMather
Uhmm, put that line anywhere except on the midpoint.
I thought I even demonstrated that in the video?
Yep, I just watched it again.  I think it was 3:18.
Now it is okey.
Why there are two coincident symbols.
undefined
JDMather
I don't know - it is just the way Inventor does it.
If you hover over one symbol you will see one line highlight and if you hover over the other symbol you will see the other line highlight.  If you delete one symbol - they are both deleted.
Note that they do not show up until you move your mouse over the yellow connection point.  At least now they are hidden until you need to delete one.
I would say - don't worry about it - just the way it is.
Just to know the reason. Because there are many things to know otherwise sketch can end in real mess. I was unable to proceed the sketch because I was unaware about midpoint technique introduced by you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
