Limit on rotational joint disappearing in flexible part assembly
Hi all,
I am trying to create a cable carrier with many chains so I decided to create a link of 10 chains and chain them up together. However, every time I try to limit the rotational connection angles between 2 of them it just disappears.
It might be an issue with the flexible part but I am not too sure, can anybody help me with this?
johnsonshiue
Hi! This is a known limitation in Rotational Limit Joint. The angular limits sometimes are removed to avoid the whole assembly from locking up without any degree of freedom. You could consider turn on Contact and Contact Solver to mimic real-world solid behavior.
Many thanks!
Software Test Engineer
