Lightning symbol custom library Inventor
j.wolbers-NoTech
j.wolbers-NoTech
Today I updated Inventor and Vault 2018 to 2020.
However, I have one problem...
In Inventor I see a lightning symbol next to my custom library.
I have already run the update tool several times but this does not fix the problem.
On the internet I read the following: This indicates that 1 or more library parts are referencing a library that no longer exists or has been migrated.
How do I make the lightning symbol disappear?
Situation custom content center:
I made a custom library in Inventor 2018.
I copied parts from the standard libraries to this custom library.
Then I added a column in the familly template with extra information which is copied to the authority property field.
I hope someone can help me with this.
Thanks in advance.
Jeffrey
johnsonshiue
Hi! Maybe you need to Refresh or Update your CC Library. Close all files and go to CC Editor -> Tools -> Refresh CC/Update CC.
Many thanks!
Software Test Engineer
j.wolbers-NoTech
I only ran the update tool from the get started menu.
Apparently that was not enough.
Thanks.
