I recently bought a book from Wasim Younis (Up and Running with Autodesk Inventor FEA ) and I am now studing the DP-16 Chapter 18 which is the lifting analysis for an offshore container.
I had a few questions regarding this analysis maybe I can get better clarifications from some members experts in simulation.
1.- When he applies the load for 4 points of lifting, he applies the total distributed load of F=2.5xtotal mass x 9.8 (as per code), which includes the tare mass (body mass) but at the same time the gravity is taken into account.
Wouldn't this action be doubling the body load/mass if I consider gravity and plus I apply a distributed load (F) to the floor, which includes the tare mass?.
2.-The custom constraints applied to the 4 corners of the container to avoid larger displacements are not very clear for me (uplift none) does this mean no separation using a spring? or why this is allowable for this particular case anyways?
@JDMather Sir, did you have the opportunity to take a look into this excersice and explain a bit more this analysis?
I am attaching the model for better understanding.
Thank you all for your help.
