Licensing Error
Licensing Error
Darkforce_the_ilogic_guy
Advisor Advisor
Licensing Error
I get this error, but I have internet and I should have a license for at lest 29 more days... and it work yestoday
CCarreiras
Hi!
Check this:
Go to" Autodesk Access" and update "sign in services" (grey icons).
Set the UAC at minimum level and deactivate anti virus during updates installation.
After installation and restoring full functionality, increase the defenses as desired.
CCarreiras
lauri_barnhart
Hello, @Darkforce_the_ilogic_guy,
Did the information provided by @CCarreiras help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
johnsonshiue
Hi! Please try resetting the license by following the steps described in the article.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-change-or-r...
Many thanks!
Software Test Engineer
