Libraries
Libraries
Message 1 of 21
Libraries
Hey JDMathers. Can you or someone do a video on creating a library and attacking it to an existing project? I do a lot of YouTube, but your videos cuts straight to the point. Thanks.
Replies (20)
Message 2 of 21
mdavis22569
Vault or no vault?
Mike Davis
Message 3 of 21
Sorry to say, but that one went over my head. I'm new to inventor.
Message 4 of 21
Mark.Lancaster
Are you talking about your own read/write library in Content Center?  Or setting up the project file to point to a location where you have common components?
In addition please specify what Inventor version you are working with...
Mark Lancaster
Message 5 of 21
mdavis22569
Quick and simple
this is without a vault
http://autode.sk/1JxAh9y
Mike Davis
Message 6 of 21
More like importing items/components and saving them in libraries instead of saying them as parts.
Message 7 of 21
mdavis22569
You need to set up a folder for them all to be in ...
In your design space, but not in your working folder ..
You're looking for setting up your own Content Center style Library it sounds like ...
it'll have all your parts there for you to pick from.
Mike Davis
Message 8 of 21
Mark.Lancaster
Gargamel1
Then setup your library folder structure using a file management tool.  Import and create your parts in Iinventor and save them to that location.  Then follow the Video mdavis just posted.
Mark Lancaster
Message 9 of 21
Setting up the project file to point to a location.
Message 10 of 21
mdavis22569
Personal ... I like using the folders way  like I was showing you.
It transfers over nicely to a Vault system if you have one (which you don't at this time)
It's easy to maintain, update and delete from.
So if you have it set up like this
...and you go to place something in assembly, and you see this
and you'll see it like this ...
As you get faster and more time on Inventor you'll be flying thru the folders to the part you need
Mike
Mike Davis
Message 11 of 21
mdavis22569
Ok here is how to make a project
http://autode.sk/1PvNl44
Mike Davis
Message 12 of 21
How do I attach a library to an existing project? Or How do I access a library that I've created?
Message 13 of 21
Mark.Lancaster
Cargamel1
Assuming you are talking about a custom content center library....  Select the content center icon and place a check mark next to your custom content center library.
Mark Lancaster
Message 14 of 21
i have Libra1 and Libra2 checked. How do I access it from assemblies?
Message 15 of 21
Still unable to access libraries from existing project. I noticed you started a new project during yolur example. Can you do a video of attaching libraries to an existing project?  Alittle slower please. Also during your video you highlited libraries and clicked the plus sign, that didnt work for me.
Message 16 of 21
Mark.Lancaster
Cargamel1
You need to clarify which library method you are referring too.  There's the content center library configuration and then there's a folder setting located in the Inventor project file that you browse to and define sub-folders on your machine (or network) and instruct Inventor to use that location as a library.
The two are totally different.
Mark Lancaster
Message 17 of 21
Content center liberaries.
Message 18 of 21
Mark.Lancaster
Gargamel1
In your existing project did you select the content center library icon button and place a check mark next to your custom read/write libraries?  Then in your assembly select place from content center,  When you do that, Inventor is looking at (and showing) all of the available libraries that you selected for that given project.  So your (content center) parts associated to your two libraries should be listed.
Mark Lancaster
Message 19 of 21
Here is a video of what I have been doing. Librara1 and Library2 have been checked, but I cant access it from place.
Message 20 of 21
I still need help accessing content center libraries from my existing project. I've setup 2 libraries both have been checked and I am still unable to access them from my project. Can someone let me know where I went wrong?
