We use Vault and Inventor 2011. We started off with library folders with certain folder structure, now we decided to change the folder structure so we have two different main library folders (with different folder structure), all under one Vault project file.
Files inserted from the first library work fine, we just started using second and it seems that there are some problems with them. Every time I open an assembly that is connected with those new library files Inventor asks for a path and shows a pop up that I attach. New libraries are within the folders under main project file, so why problems with paths?
