Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Curtis_Waguespack has posted the following idea in the Inventor IdeaStation for LOD parts: http://forums.autodesk.com/t5/ideas/v2/ideapage/blog-id/v1232/article-id/1401/page/1#comments
Autodesk has marked the idea as "Accepted", but I'm wondering if anyone has come up with a decent way to mimic this functionality until Autodesk implements it?
With iParts, when I change an iProperty (such as Stock Number), or do any other sort of change while in "Factory" mode, that change should be shared with ALL members unless it's explicitly added to the iPart table--but that's not the case. iProperties are not shared with all members--I have to explicitly add them to the table and keep them in sync manually, or the property doesn't show up right on drawings. We use custom iProperties as well, some of which are created at the Assembly level by iLogic, and these are a pain to keep up to date with iParts.
With derived parts, there just isn't enough control over the part's features. I can remove some basic featuers (like fillets), and I can add features, but that's about it. In addition to this, not only iProperties but even more surprisingly, the material is not derived into the derived part, and there's no way to create this link. If the material of the base part is changed, it's possible drawings of the derived part could be produced and handed out with the wrong material and you'd never even know it, unless you remembered to update all of your derived parts (and knew that was necessary in the first place).
So, until LOD parts are implemented, does anyone know of a way to have the feature-control of iParts but still maintain shared iProperties between members? Or how to achieve the same linked iProperties (and material) with Derived parts?
Thanks for any suggestions š
Can you give a good detailed example of what you are trying to accomplish or what you are trying to do here?
I understand your complaints but don't have a good understanding of exactly what you are hoping to accomplish here..
Give me a good example and I'm sure we can suggest a good workaround or the proper way it should be handled in Inventor.
@mcgyvr wrote:Can you give a good detailed example of what you are trying to accomplish or what you are trying to do here?
Hi @mcgyvr, I know it's been a long time but I've run into issues with this again, so I can give a couple examples.
Here are some of the issues with using the iPart workflow as opposed to a Part LOD:
All of this could be avoided if we had LOD functionality in parts.
I've realized that what we really need is not a new "LOD Part" functionality, but for iParts to behave in a more streamlined way. So I finally made an IdeaStation post suggesting some changes to how iParts and Derived Parts behave. These changes should eliminate the primary reasons that users have to forgo the otherwise great capabilities of iParts and Derived Parts, and make working with Part Configurations much easier.
IdeaStaion suggestion: Improvements to iParts, Multi-body, and Derived Parts
The attached example (Inventor 2016) may be of some use to you. I represent a machined part in several states with assembly levels of detail. In this example I show the finished part, two intermediate manufacturing steps, and a simplified representation of the finished part (without chamfers and fillets).
Some things to notice:
I will post a sheet metal example below.
Here is an example sheet metal assembly. Here my goal is not to represent a single part in various stages/levels of detail, but to represent a simplified assembly. As with the machined part example, I use a substitute part. I often use this approach when I'm sending simplified 3D CAD data to a third party. I also often use it to create drawing views with less superfluous geometry like bend reliefs, tangent edges, etc.
Thanks for putting that together, @alewer. That seems like a very nice workflow for showing different version of a part. The biggest drawbacks are the Derived parts won't derive their material or iProperties from the master part, and there are several files to keep track of.
If iParts functioned as they should (such that geometric information like work features and feature patterns wasn't lost to the members) the result would be virtually the same as your workflow, minus the need for the Phantom assembly with the Definition part.
And if iParts further functioned as Inventor users wish they did--as a single file, and where the material and iProperties are kept in sync between members unless specified otherwise--then the iPart would truly be the perfect answer to Part configurations, as it's intended to be.
Thanks very much for sharing your workflow, @alewer, it's very appreciated. We may implement this workflow until iParts are improved.
