Learning path tutorials
I recently updated to Inventor 2022 and was surprised to see that the learning path tutorial that was on 2019 was not there.  I’m a teacher and would like to use the interactive tutorials with my students because they do such a good job giving students the basics.  Is there a way to get those tutorials on Inventor 2022?
SharkDesign
Should be under 'get started' you may need to download the tutorial or change your filter to show other tutorials.
  Inventor Certified Professional
SharkDesign
Paul.Normand
While it is true the 2019 Learning Path tutorials were removed in R2020, if you are using the same computer and didn't remove them, they are still available under the Installed Tutorials area - minus the footprint path navigation. If you did uninstall them, you can get them back by installing a copy of 2019 or by copying them from a machine that still has them installed. Copy them from here: C:\Users\Public\Documents\Autodesk\.desktop-connect\.docstore\guided-tutorial-plugin\INVNTOR\2019\enu to the same location on the destination machines.
That said, the replacement get started tutorials are available for download if  you you set the filter to All Available + Quick Start. There are Get Started Tutorials for Sketch/Parts, Assemblies, Drawings, and others in this area.
I hope that helps.
Cheers,
Paul
Paul Normand
Principal Content Developer/SME
Design Lifecycle and Simulation (DLS)
Autodesk, Inc.
Thanks I will give it a try.
