Leader text issues pointing at line
YannickEnrico
Advisor Advisor
Message 1 of 12
YannickEnrico
Any explanation for this?
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Replies (11)
Message 2 of 12
johnsonshiue
Hi Yannick,
This type of behavior is probably geometry related. For some reason, Inventor got confused by which model edge corresponds to the selected view edge. Open the part and go to Manage -> Rebuild All, update the assembly, and go to the drawing. Does it work better then?
Many thanks!
Software Test Engineer
Message 3 of 12
YannickEnrico
Hi @johnsonshiue
Thanks for getting back to me
Unforunately rebuilding both the skeleton and the single part as well as updating the assembly doesn't produce a different result
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 4 of 12
jtylerbc
I've seen it before, but never had a clear reason for it.  Seems like for me, it always pops up when I don't have time to investigate and need to get something finished.
Message 5 of 12
johnsonshiue
Hi Yannick,
Then I need to see the files. Please zip up the assembly and share it with me directly johnson.shiue@autodesk.com.
Many thanks!
Message 6 of 12
YannickEnrico
I have sent you a mail for inspection
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 12
johnsonshiue
Hi Yannick,
I have not received an email from you today. I am not sure what happened. Please resend it to johnson.shiue@autodesk.com.
Many thanks!
Message 8 of 12
YannickEnrico
Hi @johnsonshiue
I sent it again. It takes up 16 mb - I hope that isn't a problem.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 9 of 12
johnsonshiue
Hi Yannick,
Our email system allows up to 50MB attachment. You had sent me files before. But, for some reason, I am not seeing an email from you. Please resend it or share it on a cloud drive of your choice and grant access to me johnson.shiue@autodesk.com.
Many thanks!
Message 10 of 12
YannickEnrico
Okay, I sent you an autodesk drive link.
I attempted to PM it to you, but for some reason I cannot use the message system here. I have reached my limit of messages, despite not having sent any since 2018...
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 11 of 12
johnsonshiue
Hi Yannick,
Many thanks for sharing the files! I took a quick look at the drawing. Without disclosing the proprietary information, I can share some findings here.
I cannot explain the behavior. There is some sort of geometry ID mix-up. It should have worked fine. The only way to clear it is to set the view to Raster (Make View Raster) and then set it back to Precise (Make View Precise). After that the leader text can be attached to the edge properly.
I will work with the project team to understand it better. However, I suspect this is geometry specific and it could be fairly difficult to find a general fix.
Many thanks!
Message 12 of 12
YannickEnrico
Hi Johnson
Thanks for looking into this. I'll return if I experience it again
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
