How can I adjust the offset of the Leader (or Balloon) so it is closer to the text itself? See attached?
You can control that using the text position and offset value of the leader in the styles editor.
Hope it helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I tried this and it doesn't work. I set it to .001" and the leader line is still spaced the same distance from the text.
Did you try changing the attached text position option as well. What version of Inventor and the service pack level you are.
Did you make sure that the leader style you modified, is the one set as your default in "Object defaults"?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I tried both settings but nothing has changed. I'm using IV 2012 SP1.
Can you please provide me your idw file and also a screenshot of how you want to place it. I will correct it and keep you posted.
I know this is a really old thread, but I'm also having this issue and looking for the answer. Was this ever resolved?
removing offset for leadered annotations is not possible.
You can post the idea to Inventor IdeaStation, maybe there are more users who will find this feature useful.
Thanks for posting,
Martin Bernat
Now I took a closer look at the original question and not sure if this was meant for the LeaderText or Balloon. There is a difference between those two.
For Balloons (with no shape around) this can be achieved in Balloon style > Symbol size - uncheck the Scale to Text Height and set the Size to 0.001. The leader should then be much closer to the text.
Martin,
When the balloon style is set to not have any Shape around the text, the options for Scale to Text Height and Size are greyed out.
However, I believe that if you change those settings when they are enabled (while having selected an option with a Shape around the text) and then change back to having no Shape I do think this offset is effected.
I think it would be a good improvement to allow the Size to be modified while "none" is selected for balloon Style.
