Inventor Forum
Leader Text and Balloon Text Question
10 REPLIES 10
Message 1 of 11
SteveFrey
1541 Views, 10 Replies
How can I adjust the offset of the Leader (or Balloon) so it is closer to the text itself?  See attached?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
10 REPLIES 10
Message 2 of 11
You can control that using the text position and offset value of the leader in the styles editor.
Hope it helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 3 of 11
I tried this and it doesn't work.  I set it to .001" and the leader line is still spaced the same distance from the text.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 4 of 11
Did you try changing the attached text position option as well. What version of Inventor and the service pack level you are.
Message 5 of 11
Message 6 of 11
I tried both settings but nothing has changed.  I'm using IV 2012  SP1.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 7 of 11
Can you please provide me your idw file and also a screenshot of how you want to place it. I will correct it and keep you posted.
Message 8 of 11
I know this is a really old thread, but I'm also having this issue and looking for the answer. Was this ever resolved?
Message 9 of 11
MartinBernat
in reply to: jcstevens
removing offset for leadered annotations is not possible.
You can post the idea to Inventor IdeaStation, maybe there are more users who will find this feature useful.
Thanks for posting,
Martin Bernat
Message 10 of 11
MartinBernat
in reply to: MartinBernat
Now I took a closer look at the original question and not sure if this was meant for the LeaderText or Balloon. There is a difference between those two.
For Balloons (with no shape around) this can be achieved in Balloon style > Symbol size - uncheck the Scale to Text Height and set the Size to 0.001. The leader should then be much closer to the text.
Message 11 of 11
jcstevens
Martin,
When the balloon style is set to not have any Shape around the text, the options for Scale to Text Height and Size are greyed out.
However, I believe that if you change those settings when they are enabled (while having selected an option with a Shape around the text) and then change back to having no Shape I do think this offset is effected.
I think it would be a good improvement to allow the Size to be modified while "none" is selected for balloon Style.
