Latest Updates | New Knowledge Network Articles | Inventor
CGBenner
Community Manager Community Manager
Message 1 of 1
CGBenner
These haven't been posted for quite some time... We're going to try to start posting them again from time to time.  Happy reading!!
February 2021 - Inventor
Flat-pattern-contour-lines-not-visible-in-Inventor-drawing-view
Semi-visible-Autocad-shx-fonts-in-Inventor-drawing-titleblock
Wrong-Item-Number-for-newly-inserted-Parts-in-an-Inventor-Assembly
Pressing-CTRL-Right-Mouse-Button-does-not-show-up-the-marking-menu-in-Inventor
How-to-open-an-Inventor-assembly-with-all-the-visibility-object-options-turned-off
The-Inventor-Content-Center-Flange-DIN-EN-1092-2-Hubbed-Slip-On-Flange-for-Welding-Type-12-PN-16-Duc...
Unexpected-ClientFeature1-in-Autodesk-Viewer-after-publishing-the-Inventor-Factory-Design-Layout
Exported-Inventor-BOM-thumbnail-doesn-t-scale-correctly-in-Excel
Feature-below-End-of-Part-marker-is-still-active-in-Inventor-part-file
Best-method-to-create-drafts-on-reinforcement-ribs-for-plastic-injection-molded-parts-in-Inventor
Error-during-calculation-in-Inventor-Gear-Design-Accelerator-Calculation-indicates-design-failure
How-to-disable-Ignore-Individual-Punch-Representation-Settings-in-Inventor-Sheet-metal-template
Inventor-will-not-uninstall-so-that-it-can-be-reinstalled
Expression-column-does-not-recognise-quotes-as-a-space-in-Inventor-2021-2
The-density-of-all-material-is-shown-as-zero-in-iProperties-of-all-Inventor-part
Extrusion-loses-geometry-depending-on-how-it-is-defined
Length-parameter-not-calculated-correctly-when-changing-length-of-a-Content-Center-Standard-part-in-...
Point-cloud-not-shown-correctly-in-Inventor
3D-Sketch-is-not-behaving-as-expected-when-making-large-dimension-changes-in-Inventor
Inventor-2021-hangs-loading-the-Vault-Client
Inventor-taper-tapped-hole-with-countersink-creates-unexpected-cone-hole
Text-size-changed-when-editing-dimension-text-is-not-applied-to-dimension-in-Inventor
Inventor-locks-up-trying-to-access-Content-Center-on-Vault-server
Component-transparency-is-not-reflected-in-drawing-view-in-Inventor
When-converted-to-a-sheet-metal-part-from-an-inventor-part-the-part-will-not-flatten
Inventor-2021-crash-resolving-and-updating-drawing-views
White-background-for-Inventor-drawings-once-opened-in-AutoCAD
Converting-to-Freeform-of-a-Sphere-cone-transition-type-of-part-fails-in-Inventor-2020-and-2021
RFA-created-frim-Inventor-has-missing-items
User-Reported-Frame-assembly-Step-file-conversion-frame-member-not-as-per-the-model-in-Inventor
What-is-the-significance-of-green-cube-glyphs-in-Inventor-Degrees-of-Freedom
3D-PDF-files-exported-from-Inventor-are-empty-if-the-laptop-is-connected-to-USB-C-access-point
Can-t-change-size-of-a-published-ipart-in-the-tube-and-pipe-environment-after-placing-it
Link-Inventor-Part-Revision-to-Drawing-Title-Block
Unable-to-zoom-in-with-preview-of-DWF-after-creation-from-Inventor-job-processor-through-Design-Revi...
How-secure-are-Autodesk-Shared-Views
Participate-in-Assembly-and-Drawing-Section-option-changes-in-family-template-after-migration-in-Inv...
March 2021 - Inventor
Translation-for-Published-ipart-about-include-and-excude-are-opposite-in-Inventor-Chinese-version
Inventor-3D-Sketch-line-get-corrupt-when-create-3D-Sketch-with-ORTHO-mode-and-dynamic-dimension-toge...
Open-button-is-not-working-while-inserting-AutoCAD-DWG-to-Inventor-Part
Autodesk-Analytics-runs-in-the-background-and-consumes-12-8-of-the-cpu
Russian-characters-are-not-searchable-in-exported-PDF-file-from-Inventor-drawing
How-to-change-the-reference-in-Inventor-presentation-file
What-is-the-best-file-format-to-transfer-3d-Solid-AutoCAD-objects-to-Inventor
Assign-item-for-Inventor-Assembly-fails-with-One-or-more-of-the-selected-files-cannot-be-assigned-to...
NPT-1-1-2-Pipe-Thread-is-1-5-deg-instead-of-1-79-deg-for-Portuguese-Inventor
Shadows-not-visible-when-suing-a-bright-background-in-Inventor
Default-ViewCube-Orientation-setting-is-not-effective-when-creating-new-document-in-Inventor
Inventor-2021-crashes-on-exit-after-installing-Microsoft-update-KB4601056
Inventor-dwg-is-created-as-an-idw-before-saving-it
Is-it-possible-to-import-AutoCAD-block-as-Sketch-Symbol-in-Inventor-drawing-while-maintaining-block-...
Unable-to-move-or-drag-drawing-view-when-detail-view-format-is-ANSI-in-Inventor
User-Reported-Error-when-using-Custom-Content-Center-member-in-Frame-Generator-in-Inventor
Stress-analysis-results-in-Inventor-does-not-match-with-Fusion-360-stress-results
Some-projected-geometry-from-the-Inventor-2020-flat-pattern-sketch-is-missing-when-the-sketch-is-exp...
White-stripes-shown-in-Adobe-Illustrator-when-opening-a-PDF-created-with-Inventor
Automatically-remove-reservations-steal-checkout-on-legacy-Inventor-files-after-being-opened-from-Va...
Different-model-tree-structure-in-Inventor-presentation-file-after-structure-change-in-Inventor-asse...
How-to-create-a-punch-tool-and-make-it-available-to-be-constrained-in-an-Inventor-assembly
How-to-delete-a-model-space-view-from-the-Inventor-browser
Importing-of-AutoCAD-Electrical-data-Defining-cable-cores-in-Inventor
Parts-that-no-longer-exist-are-displayed-in-drawing-views-in-Inventor
Command-shortcuts-need-to-be-confirmed-with-the-Enter-in-Inventor-in-order-to-be-ran
DIN-11850-Tube-and-Pipe-elements-are-not-available-in-Inventor-Content-Center
Resolution-linked-Excel-table-in-exported-from-Inventortor-drawing-to-PDF-file-from-Autodesk-Drive
Any-Model-Parameter-Change-event-not-fired-properly-in-Inventor-2021-2
Corrupted-density-and-no-mass-calculated-for-Inventor-parts
User-Reported-Using-custom-bend-deduction-equation-calculation-does-not-match-while-comparing-with-I...
How-to-determine-the-moment-of-inertia-and-the-center-point-of-an-area-or-sketch-in-Inventor
Importing-multilayered-DXF-file-to-Inventor-Nesting
Error-Bend-has-only-one-side-Please-check-the-Thickness-setting-in-the-sheet-metal-styles-in-Invento...
How-to-create-parallel-coordinate-systems-in-Inventor-sketch-Region-Properties
Sketched-Symbols-show-Slow-Performance-in-Inventor-2019
Revision-table-does-not-accept-characters-from-other-fonts-and-cannot-be-printed-properly-in-Invento...
A-cyclical-constraint-dependency-was-detected-when-using-Move-face-command-in-Inventor
How-to-add-shortcut-key-for-commands-that-do-not-exist-under-command-name-list-in-Inventor
Image-wrap-doesn-t-show-up-in-members-inside-Inventor-assemblies
Inventor-s-FEA-simulation-is-unexpectedly-separating-this-model
Inventor-Circular-patterns-are-not-honored-in-Punch-Tools
Browser-node-name-is-different-from-file-name-in-Inventor
How-to-export-Inventor-Stress-Analysis-result-to-step-file-or-export-data-points
How-to-link-an-AutoCAD-drawing-into-an-Inventor-drawing
Flatt-pattern-punch-representation-defined-in-during-inserting-the-punch-tool-doesn-t-display-proper...
How-to-filter-the-Parts-List-with-specific-criteria-in-an-Inventor-drawing
Incorrect-QTY-value-in-parts-list-in-Inventor
The-sketch-does-not-contain-a-valid-section-line-while-copy-and-Pate-operation-in-Inventor-drawing
Long-waiting-time-when-selecting-or-importing-specific-NX-files-in-Inventor
Material-list-doesn-t-show-up-before-saving-an-Inventor-iPart
Model-edges-in-a-Section-View-are-not-correctly-shown-in-an-Inventor-Assembly
Updating-a-part-in-Inventor-2021-using-iLogic-leads-to-a-large-performance-drop-and-increased-file-s...
Frame-members-are-not-correctly-mirrored-when-miter-is-applied-in-Inventor
April 2021 - Inventor (so far)
Discrepancies-between-Inventor-assembly-and-Shared-View
Unable-to-migrate-a-skeleton-of-an-Inventor-frame-generator-assembly
Install-Failed-when-installing-AutoCAD-2022
Decal-is-not-shown-on-planar-face-in-Inventor-part
Cannot-import-a-file-into-my-ipt-file
How-to-export-the-loads-and-the-constraints-from-the-dynamic-simulation-to-the-part-in-Inventor
February 2021 - April 2021 (so far) - Inventor CAM & Nastran
Does-Inventor-have-an-Inspect-Surface-tool-like-Fusion-360
Behaviour-of-selecting-Stock-box-point-on-models-in-Inventor-CAM-2021-CAM-version-8-3-1-23871-is-dif...
Inventor-CAM-suddenly-stopped-working-properly
How-to-engrave-single-line-text-on-a-planar-surface-in-Inventor-CAM
Inventor-CAM-adaptive-toolpath-retracted-while-tool-was-still-engaged-in-material-and-snapped-the-to...
Rigid-connectors-definition-in-Inventor-Nastran
Delays-in-case-of-failed-calculation-in-Inventor-Nastran
Linear-Buckling-only-calculates-one-mode-outside-of-desired-bounds
Result-file-format
How-to-reload-results-for-calculated-model-in-Inventor-Nastran
Is-it-possible-to-use-bolt-connectors-with-shell-elements-in-Inventor-Nastran
Negative-displacement-values-cannot-be-presented-in-Inventor-Nastran
How-to-save-project-with-all-components-to-different-disk-or-folder-for-analysis-in-Inventor-Nastran
How-are-cross-sectional-properties-for-structural-members-calculated-in-Inventor-Nastran
Mesh-not-created-for-solid-idealization-in-Inventor-Nastran
Elements-are-deleted-in-Idealization-without-a-deletion-criterion-in-a-Nastran-Explicit-analysis
Safety-factor-presented-as-0-for-loaded-model-in-Inventor-Nastran
Ilogic-in-Inventor-Nastran
Parametric-models-calculations-in-Inventor-Nastran
Steel-plate-resting-on-concrete-block-simulation-in-Inventor-Nastran
Fatal-error-5004-while-buckling-analysis-in-Inventor-Nastran
Meshing-error-while-mesh-generation-for-thin-walled-solid-object-in-Inventor-Nastran
Can-Inventor-nesting-studies-be-combined
February 2021 - Inventor Professional
Exported-from-Inventor-simplified-part-file-to-STEP-or-IGES-generate-multibody-part
iLogic-From-appears-while-check-in-files-from-Inventor-to-Vault
Parts-list-in-a-drawing-is-showing-wrong-Item-Numbers-in-Inventor
Connect-Fittings-stop-working-in-Inventor-Tube-and-Pipe-assembly
Inventor-Factory-unresponsive-while-with-synchronising-with-AutoCAD
Part-is-highlighted-in-transparent-color-instead-of-opaque-color-in-Inventor
Problems-encountered-while-saving-the-document-on-saving-an-Inventor-2012-part-file-in-a-newer-versi...
Cyclical-Constraint-Dependency-when-trying-to-create-a-Flange-in-Inventor
How-to-export-an-Inventor-flat-pattern-as-a-3D-AutoCAD-DWG
Positional-views-are-reverting-back-to-the-master-view-in-Inventor
Driven-Dimension-Properties-are-disabled-within-Part-Sketch-Right-Click-Menu-in-Inventor-2021
Migrated-Vaulted-Custom-Content-Library-table-changes-with-Inventor-2021are-not-saved
No-Model-is-shown-in-an-exported-3D-PDF-from-Inventor
Can-the-Possible-Relationship-Loss-message-be-suppressed-when-doing-a-Component-Replace-in-Inventor
Performance-issues-while-hatching-region-in-Inventor
Specific-icon-for-structured-drawing-part-list-is-available-only-for-the-Inventor-amber-theme
A-large-custom-content-center-library-will-not-migrate-in-Inventor
How-to-Edit-Property-Fields-Prompted-Texts-Attributes-Reference-in-Inventor-drawings
How-to-get-the-minimum-bounding-box-dimensions-of-a-given-Inventor-part
VBA-Not-Found-Inventor-is-not-able-to-detect-VBA
No-thread-lines-are-shown-in-an-Inventor-drawing-for-non-orthogonal-holes
Content-Center-naming-removes-space-in-part-name-within-Inventor-2021
The-offline-help-for-Inventor-2021-is-trying-to-use-non-existent-Adobe-Flash-to-show-videos
Sketch-Block-Visibility-does-not-change-when-in-a-Inventor-2D-Sketch-and-a-non-Master-View-Represent...
Inventor-2021-2-update-will-not-download
What-are-the-best-file-formats-to-import-into-Inventor
Table-Replace-column-not-created-when-authoring-a-Tube-and-Pipe-iAssembly-in-Inventor-with-German-la...
AutoCAD-dwg-gets-scaled-after-using-it-as-layout-underlay-in-Inventor
Relief-Width-Minimum-Remnant-in-a-Flange-creating-an-unexpected-cut-in-an-Inventor-Sheet-Metal-Part
Tolerance-from-2D-Sketch-is-not-updated-on-an-Inventor-Drawing-when-using-Retrieve-Model-Annotation
In-Trial-Version-Inventor-crashes-with-Dezign-Works-add-in
March 2021 - Inventor Professional
Unable-to-set-as-non-visible-a-part-in-an-Inventor-drawing-view
RCE-0x80131500-Translation-failed-when-updating-an-Inventor-Part-Assembly-referencing-a-RVT-file
Inventor-s-Save-Copy-As-is-not-Automatically-opening-the-new-file
Goals-and-Criteria-and-Run-panels-are-shown-as-blank-in-Inventor-Stress-Analysis-environment
After-migration-Content-Center-some-custom-families-lost-parameters-information-in-Inventor
Frame-members-are-missing-in-exported-STEP-or-DWG-file-from-Inventor
Send-parameters-to-the-embedded-Excel-by-iLogic-In-Inventor-stops-working
Library-file-migration-failed-a-database-error-occurred-No-library-is-available-for-next-step-when-m...
Browser-bar-is-not-attaching-to-the-open-session-in-Inventor
Inventor-is-not-finding-the-Inventor-Nastran-addin-after-it-is-installed
Exported-parameters-show-the-inch-symbol-instead-of-in-in-Inventor-custom-iProperties
Find-related-files-from-the-Inventor-open-dialog-doesn-t-work-properly
Missing-origin-folder-in-model-tree-in-Inventor
Unexpected-behavior-while-using-iCopy-in-an-Inventor-assembly
What-is-the-definition-of-a-Redundant-Constraint-in-an-Inventor-assembly
A-black-screen-is-shown-at-the-start-of-Inventor-2021-instead-of-the-Home-Screen
How-to-define-a-constraint-that-will-fix-one-of-the-directions-for-the-whole-beam-in-Inventor-Frame-...
How-to-flip-Frame-Analysis-diagram-direction-in-Inventor
Is-it-possible-to-view-decals-created-in-Inventor-part-in-Shared-Views
Text-is-shifted-in-exported-DXF-from-Inventor-IDW
Component-paste-failed-appears-during-a-copy-of-bent-parts-to-another-Inventor-assembly
How-to-retrieve-model-annotations-for-a-flat-pattern-of-an-Inventor-sheet-metal-part
Complex-linetypes-are-not-available-in-Inventor-drawing
Existing-constraints-are-lost-when-replacing-part-with-iPart-converted-from-original-part-in-Invento...
Inventor-fails-to-compute-Flat-Pattern-of-complex-part
Missing-welding-feature-for-an-Inventor-assembly-exported-as-3D-PDF
User-reported-that-Auto-Balloon-place-a-number-for-each-part-of-a-subassembly-with-the-BOM-view-set-...
Auto-Balloon-is-showing-X-s-instead-of-the-numbers-in-some-Inventor-drawings
Outlooking-viewing-of-other-users-Calendars-stops-working-after-installing-Inventor-2021
Importing-STPs-files-takes-a-long-time-in-Inventor
Positional-representations-in-sub-assemblies-are-not-recognized-and-behave-differently-in-Inventor-S...
WARNING-SHAPE-NUMBER-XX-DOES-NOT-CLOSE-when-selecting-AutoCAD-file-as-source-in-Inventor-Nesting
Envelope-character-is-missing-in-exported-DWG-AutoCAD-drawing-file-from-Inventor
Inventor-Drawing-sketch-symbols-with-images-are-wrongly-exported-as-PDF
When-MS-Office-365-ProPlus-is-installed-Is-it-possible-to-bend-AutoCAD-to-a-new-VBA-environment-so-t...
When-inserting-AutoCAD-file-in-2D-sketch-Inventor-crashes-with-LoadLibrary-failed-with-error-126-The...
Parameters-Dialog-Box-cannot-be-resized-in-Inventor-on-4K-monitor
What-is-the-difference-between-trimmed-or-not-trimmed-beam-in-frame-analysis-results-in-Inventor
Get-length-after-the-split-of-sweeped-solid-body-in-Inventor
Parts-are-no-longer-constrainable-in-an-Inventor-assembly
Task-Scheduler-message-No-Vault-project-found-Can-not-create-task
A-part-is-not-visible-in-an-upper-level-Inventor-assembly
Inventor-assembly-can-t-be-saved-after-changes-in-representations
Material-appearances-graphical-glitches-on-Inventor-assembly
When-creating-nest-for-assembly-from-other-CAD-systems-parts-are-not-recognized-as-sheet-metals-in-I...
Exporting-BIM-Content-building-components-to-RFA-crashes-Inventor-2021
Component-selection-becomes-slow-when-project-type-is-set-as-Vault-in-Inventor
Files-outside-of-active-project-workspace-when-saving-files-in-Inventor
Can-t-remove-images-from-Title-Block-in-Inventor-drawing
Inventor-2021-is-not-seeing-any-Vaulted-Content-Center-Libraries
Is-it-possible-to-set-default-paper-size-in-Inventor-drawing
Orphaned-Revit-reference-in-Inventor-assembly-causes-check-in-error-due-to-linked-DWG-files
How-to-define-distance-alignment-between-two-views-in-Inventor-drawing
Vault-Browser-in-Inventor-does-not-show-the-correct-state-after-a-referenced-file-is-checked-in
Vault-grid-does-not-refresh-after-copy-design
The-file-that-is-being-saved-is-set-to-read-only
Hovering-over-geometry-in-a-drawing-with-leader-text-or-welding-symbols-crashes-Inventor
How-to-attach-sketch-symbol-to-dimension-in-Inventor-drawing
Material-does-not-appear-in-material-drop-down-list-in-Inventor
Object-selection-using-mouse-is-too-sensitive-and-prone-to-mistake-in-Inventor
Some-dialog-boxes-either-do-not-appear-or-they-appear-off-screen-for-Inventor
The-Inventor-iLogic-Design-Copy-is-coping-the-FEA-files-even-when-the-AIP-folder-is-deselected
Unable-to-snap-a-new-created-UCS-to-work-points-in-Invenor-assembly
An-error-occurred-while-attempting-to-create-the-directory-occurred-while-installing-the-Inventor-Ca...
Inventor-drawing-reacts-slowly-to-mouse-drag-and-interactions
Missing-Vbelts-folder-during-adding-the-new-VBelt-in-Inventor
April 2021 (so far) - Inventor Professional
Error-Model-does-not-contain-appropriate-tolerance-feature-in-Inventor
Not-possible-to-create-shaft-groove-when-using-Parallel-Key-Connection-Generator-in-Inventor
User-Reported-Inventor-2021-crashes-when-create-new-route-and-click-on-run-with-custom-addins
Opening-IDWs-from-Solidworks-PDM-to-fail-with-Inventor-View-with-a-registration-error
Templates-from-Fusion-360-desktop-connector-are-not-visible-in-Inventor
Inventor-crashes-on-iPart-member-generation-when-logged-in-to-Vault
Creating-a-bending-machine-output-file-crashes-Inventor
Mirror-of-Loft-following-complex-rails-does-not-produce-same-result-within-Inventor
Can-t-change-the-appearance-color-of-some-parts-in-Inventor
Incorrect-PDF-template-is-not-used-when-publishing-3D-PDF-file-in-Inventor
Save-tab-in-iProperties-changes-value-after-saving-Inventor-part-file
When-trying-to-check-in-Inventor-assemblies-to-Vault-it-fails-on-save
Dimension-text-color-is-changed-in-exported-AutoCAD-DWG-from-Inventor-after-using-custom-macro-to-ch...
Incorrect-edge-view-in-loaded-AutoCAD-DWG-as-DWG-Underlay-in-Inventor
Unable-to-insert-new-GOST-parts-list-table-after-deleting-existing-table-from-model-browser-in-Inven...
Editing-GOST-parts-list-style-opens-Table-style-instead-of-Parts-list-style-in-Inventor-drawing
Opening-and-Converting-a-STEP-file-that-previously-exported-from-Frame-Generator-assembly-broke-all-...
Chris Benner
Replies (0)
