@RadoG wrote:
how to simplify large stl files in
inventor.
Let's see what you have - attach your *.stl file here.
My client have STL file from 200MBa and want to reduce files because Inventor work slowly when import file in Inventor .
Hi! Do you mind elaborating the objective here? What is the source data (an assembly or a part or scanned data)? What do you mean by "simplifying"? What do you want to do with the data after simplification?
Many thanks!
Hello @RadoG, @radoslav did you get the Meshmixer to work for you? I am checking back to see if any of the replies helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Select the Accept as Solution button if a post or posts solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
