Language changed Randomly
ron_rogersPHANR
ron_rogersPHANR
Community Visitor
Community Visitor
My language, which was originally English, has now changed to German in Inventor. I have no Idea what could have caused this to happen. The only thing I did differently was I pinned inventor to my taskbar, and now says I am running the German Version of inventor all of a sudden. Because of the situation I'm in, downloading or modifying files are not available to me. Is there a way to change it in Inventor to fix this problem I am having?
Gabriel_Watson
Try editing your shortcut to change the language on its target field, such as:
"C:\Program Files\Autodesk\Inventor 2024\Bin\Inventor.exe" /language=ENU"
Right-click > Properties on the link you use to open Inventor and see if that works.
johnsonshiue
Hi! Each language-specific Inventor has a particular desktop icon. If you use command line to start Inventor, it will default to the last run language.
Many thanks!
Software Test Engineer
