Justify Chamfer Text
chris26
chris26
Is ther a way to change the justification of the text for a Chamfer Note?
I've tried changing the style, tried editing the text.  neither worked.
As you can see in the jpeg, justification needs to be flipped.
undefined
lesmfunk
I noticed that your leader landing is missing. If I adjust the leader landing length, the justification remains on the same side as when the landing was last adjusted. Inorder to justify to the other side, I have to drag the landing to that side.
Davarn-ToolGuy
The chamfer command does not allow multi segment leader lines unlike the actual Leader command.
undefined
The successful chamfer message is actually a Leader command that I manually typed the chamfer message into.
This might be a good suggestion for the Idea Station.
David Arnold
Designer-New Dies
Motor City Stamping Inc.
lesmfunk
Yes, a good one for the Idea Station.
I have used [the leader] method in the past and one time it was a $2000 mistake. The leader does not update to a change in the source geometry.
Sometimes I remove the "Chamfer" word from the note to save space on busy drawings. Everyone knows what .06 x 45° means. If they don't, they will ask.
Also, I change the style to read UPPERCASE as in David's leader. Don't know why the default isn't UPPERCASE.
Davarn-ToolGuy
That is a good point, but just to clarify, I presented the Leader command to demonstrate the difference between commands, but I should have pointed out the main (and costly) downside in using it.
The recomendation to use the Idea Station is the Ideal solution.
SBix26
By all means, add the IdeaStation post (and include all Feature Notes in the request: Hole/Thread, Chamfer, Punch, Bend).  I will support it and I'm sure many others will, too.  There might already be one there, in which case a duplicate isn't necessary.  Be sure to post a link in this thread to your new idea, or to an existing one that you find.
A workaround to avoid the costly errors, though, is to use part parameters in your Leader Text.  It's tedious to find them in a busy part, but should at least avoid mistakes that have big time and money implications:
undefined
Sam B
Inventor Professional 2015 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Cadmanto
I am not seeing where this got addressed in the idea station, so I created the idea here.
https://forums.autodesk.com/t5/inventor-ideas/justification-for-chamfer-notes/idi-p/8141507
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
