Announcements
IV Drawing, how do I make a sheet not appear in the sheet count or printable?
chris
chris
Is there a way for a specific sheet in an Inventor drawing to show up as invisible for print and page count?
I have a couple extra sheets in my drawing for various info that I don't want printed and I don't want added to the total page number (1 of 7) count
chris
Nevermind, they could have labeled that RMB sheet properties, I assumed "edit sheet" meant sheet size only, duh, problem solved
EdvinTailwind
Good to know! Those check-boxes were options I never noticed as I never looked for them...
ldutkaTUZ58
In your printer setting, you can always specify which sheet to omit, such as sheets 1 through 6, you can omit sheet 4 and enter "1-3, 5,6" and the printer will NOT print sht 4. Is that what you're trying to do? Good luck.
EdvinTailwind
@ldutkaTUZ58 - As the thread author already found out, here is a permanent way of excluding sheets from being printed:
ldutkaTUZ58
Never knew about THAT feature. I just know at the first printer window pop up, the sheets can be picked. Thanks
